2004 Yamaha Warrior only runs on choke please help
Old Sep 24, 2015 | 09:19 AM
Bernhard's Avatar
Bernhard Schmidt
Question 2004 Yamaha Warrior only runs on choke please help
I bought a 2004 Yamaha Warrior 350 a few weeks ago rode it one day all fine. But the next day it started sputtering and finally cut out. So I cleaned the carb and it ran again for one day thr I had the same problem so I cleaned the carb again put the problem persists I'm rally disappointed and don't know what the problem could be if any one has any knowledge what it could be please let me know thanks
Old Sep 25, 2015 | 12:45 PM
95wolv's Avatar
The choke on the Warrior is an enrichment choke, in other words, it lets extra gas in to help a cold motor start instead of a choke butterfly valve like a lot of carbs. The fact that it runs with the choke tells me one thing, you are not getting enough fuel to the motor without the extra the choke provides. You either have a low float level starving your quad for gas, or your pilot jet is getting water or trash in it, it is VERY tiny and takes nothing to plug up, and without it, your quad won't idle. You have to remove it, make sure it is spotless, I use a strand of wire from a wire brush to probe out all the holes when I clean one, and blow it out with carb cleaner and then an air gun, then shine a light on it to make sure all the ports are open. Then, I would get a small inline filter from your tank to your carb, sounds like you have some stuff in your tank that keeps gumming up your carb.
njrider64
Jul 4, 2017 01:40 AM
mikey426
Jun 17, 2015 03:53 PM
dano00
Oct 7, 2000 08:13 PM
PuhiStrain
Sep 9, 2000 01:36 PM
dunc_n
Aug 26, 1999 09:32 PM
