chinese 110cc atv "idle screw"?
Old Jan 20, 2016 | 03:50 PM
TaoTao110D's Avatar
Default chinese 110cc atv "idle screw"?
Hey guys, I have a chinese Taotao 110cc atv and it seems like all the adjustment screws have a brass block off plug in them, all of them except one, which the manual describes as the "idle adjust screw". Im used to carb's have an idle air adjustment screw and an idle fuel adjustment screw. Is this single "idle adjust screw" on my chinese 110cc carb the idle AIR adjustment, idle FUEL adjustment, or somehow both in one screw? Im just kind of confused since Im more used to seeing two, one for idle air and one for idle fuel.
Thanks for the clarification everybody!
Old Jan 20, 2016 | 08:20 PM
TaoTao110D's Avatar
I guess another way people describe them are idle speed adjustment screw and idle mixture adjustment screw. Which one is this single adjustment screw on my chinese 110cc atv?
Old Jan 21, 2016 | 02:48 AM
It is going to be the idle speed screw. Most air fuel screws on quads are set at the factory and you are not supposed to alter them. Tuning mods like different air filters and exhausts may require a different air/fuel setting but the screw is unlikely to do much as it is for the mixture at low speeds. If the bike runs OK, don't fiddle with the mixture screw, if it doesn't, the carb probably needs cleaning rather than mixture alterations.
Old Jan 21, 2016 | 07:43 AM
MPDano's Avatar
There are also write ups on removing that block, which will have the a/f screw underneath it. I just bought a generator that has a block on it, I keep getting surging idling. Cleaned the carb and no change. Ended up buying a new carb for like $18 and this one had a visable a/f screw. Richened up the mixture and away went the surging.
Old Jan 22, 2016 | 04:27 PM
TaoTao110D's Avatar
So the only exposed adjustment screw is the idle air ?
Thanks everybody!
Old Jan 22, 2016 | 05:04 PM
MPDano's Avatar
Thanks everybody!
Not all carbs, but some. If you only have one adjustable screw, then it's most likely to adjust the idle setting.
Old Jan 23, 2016 | 03:00 AM
"So the only exposed adjustment screw is the idle air ?"
No the adjustable screw is the idle speed, the air/fuel mixture screw may, or may not be sealed off.
Old Mar 2, 2016 | 05:13 PM
pitbikesr4me's Avatar
I take a dremel tool with a cut off disc on it & put a slot in the air mixture brass insert then I take a straight screwdriver & unscrew the insert out, under it is you air mixture screw that you can adjust
TaoTao110D
Feb 23, 2016 10:48 PM
Lora Holland
Feb 6, 2016 09:43 AM
jpstead2@gmail.com
Jan 15, 2016 09:50 PM
JayMueller
Dec 25, 2015 11:18 AM
