Kfx 700 2004 speed mods?
Old May 9, 2016 | 11:38 PM
Nathan Osment's Avatar
Default Kfx 700 2004 speed mods?
Hi I have a kfx 700 2004 with dual big gun exhaust ,Rev box and clutch spring. Any speed mods?. Also what jet kit should I get. Thank you
Old May 10, 2016 | 07:56 AM
Scooter86's Avatar
Knows Old ATV Questions!
The sky is the limit with those Kawie v twins, but my suggestion is put some $$ into better shocks. You will be able to go faster for longer.
Old May 10, 2016 | 08:47 AM
greg74's Avatar
Sounds like you've already got some decent mods. The KFX 700 is pretty fast completely stock, yours should be significantly faster than that. I just got my Brute Force and I can attest that the v-twin in it has noticeably more punch than the Grizzly 660 I had previously.
Old May 10, 2016 | 09:24 AM
Fasteratv's Avatar
Go to kawieriders.com. There are many many mods you can do. The 12 hole mod, Twin Air Power Flow Filter System, rejet, then clutch mods.
Old May 10, 2016 | 09:25 AM
Fasteratv's Avatar
Greg....are you now a Kawie man? Love those V twins!
Old May 10, 2016 | 10:27 AM
Thanks lots of new ideas. how about which jet kit would work best? Thanks
Old May 10, 2016 | 10:40 AM
Fasteratv's Avatar
Best performance will not be a jet kit....just use the larger Keihin main jets when you decide to do the mods....Join the Kawieriders.....tons of info on this...
Old May 10, 2016 | 05:37 PM
What's the best jet kit for dual big gun exhaust?
Old May 10, 2016 | 07:36 PM
hydrex's Avatar
Dynojet stage 1 might be a good choice. Also, perhaps cam shafts? As far as carb tuning, you can't beat a wideband O2 . I've put one on my 2001 Arctic Cat 500 after doing a 5 degree advance timing key mod and a Web racing cam. I used the Dynojet needle and spring, drilled the slide 1/8" and ended up using Keihin jets. Comparing reading spark plug chops to using a wideband to tune is like comparing flapping your arms to flying a F15. If you do a 5 degree advance key, you have to run premium gas, gave me a nice boost with the cam. Check out Web racing cams.
Old May 11, 2016 | 05:01 AM
greg74's Avatar
I am now. I do definitely see the appeal of their v-twins over Yamaha's single for sure. First Kawasaki for me.
