Sport Quads Discussions on sport quads.
400ex front caliper wont go on after new brakes
Old Jun 5, 2016 | 05:52 PM
Chris.400's Avatar
Default 400ex front caliper wont go on after new brakes
Well my 400ex was acting up. So I saw the wear indicator was all the way out, So I replaced my pads. I new things were going to smoothly, and when I went to put the caliper back on the metal mounting plate hit the rotor, and I could not get it to go on. The metal mounting plate is supposed to move according to the service manual. And help would be great. Would like to go ride this weekend and without brakes it isn't possible.
Old Jun 6, 2016 | 12:08 PM
DirtDevil101's Avatar
I use a c-clamp to "compress" the piston(s) back...when I do this I use the old pads. If you did a simple pad swap then the new pads will be wider than the old worn pads (piston being in same position) so it wont slide onto the rotor...
One done check the fluid level in master as well...
Old Jun 7, 2016 | 09:34 AM
Chris.400's Avatar
No, that is not the problem. I found it now though. The caliper pins are rusted in place, not allowing the caliper to move back and forth, so the mounting bracket is hitting the rotor. But with a lot of penetrating oil and 3 days, Some heat on the caliper did the trick to remove it.
Old Jun 7, 2016 | 10:52 AM
Good to hear!
Pbaugh30
Jun 4, 2016 12:34 PM
1000gade
May 31, 2016 06:03 PM
Chris.400
May 27, 2016 08:17 PM
Dylan Mckee
May 23, 2016 08:03 PM
Johnny Sandlin
May 21, 2016 07:52 PM
