Tao tao 110 atv no sparky sparky
Old Jun 10, 2016 | 07:55 AM
mbushue2's Avatar
Default Tao tao 110 atv no sparky sparky
Everything electric is brand new. Stator. Starter. Cdi. Rectifier. Battery. Coil.
No spark at all. Cranks fine and strong. Remove kill wire from cdi harness and still nothing. I get signal from red/black wire on harness side but nothing to yellow and black (cdi-coil)
Old Jul 7, 2016 | 09:46 PM
armagh's Avatar
I have bought several, ( more than 4 or 5), new CDIs and they were bad out of the box. This is a problem that you can read about by clicking my name. Lynn Edwards helped me a lot with the problem, but not all CDIs that are new are good.
Old Jul 13, 2016 | 01:54 PM
Unsub's Avatar
Start measuring with a multimeter to find the fault, crank it while measuring the wires from the stator, if there's sufficient output the stator is good.
Crank it while measuring the voltage from the CDI to the coil, if sufficient output the CDI is good.
Crank it while measuring the coil etc.
You'll quickly find the problem and see if it's a bad part or just faulty installment.
Old Jul 13, 2016 | 02:01 PM
mbushue2's Avatar
Finally got it dkwn to the magnet in the stator not close enough to flywheel. Spark signal still seems weak may have to make mounting holes in magnet bracket larger to get magnet closer to flywheel
Old Jul 13, 2016 | 02:05 PM
armagh's Avatar
Can you tell us the amount that qualifies as sufficient ?
Old Jul 13, 2016 | 02:08 PM
Unsub's Avatar
Around 12-15volts on wires to charging/for AC cdi.
Around 100volts for the wire that is going to the CDI and then coil.
Old Jul 13, 2016 | 02:39 PM
armagh's Avatar
Thanks
Old Jul 18, 2016 | 07:35 AM
Anson's Avatar
I have a 110 cc tao tao that wont crank or do anything the crazy part is that even when i unplug the cdi and the regulator the wires stay hot.if anyone has detailed pics of how they hooked theres up id be greatful i just want to make it run i dont care about lights or saftey switches just want to hook wires from my stator cdi and soleniod. Please help thanks in advance
Timbo2500
Jun 8, 2016 03:50 AM
tecate1987
Jun 1, 2016 10:01 PM
lohnes68
May 28, 2016 07:43 AM
micahhoward
May 21, 2016 08:08 AM
May 19, 2016 12:54 PM
