2004 DS650 Baja X Wiring issues.....
Hey all. Been along time since ive been on these forums. Recently put a new piston in my ds650 and while removing the engine i un hooked all the wires under the dash and the main electrical connectors for the harness. Got everything back together correctly if i remember from taking it apart. My tach comes on, my lights all come on, neutral and oil pressure light work, starter button works and i can hear the relay beside the CDI click when i turn the key on. I have no spark none not even a little bit. I decided to throw a test light on the coils and there is nothing...now i originally thought i hooked up the wires under the dash wrong and that could still be the case but no matter how i hook them up i still get no power to the coils. There is a white wire with green stripe that goes to the coils from the stop/run switch on the bars it then tees over to the other coil to power it. Im not getting any power to that wire. The only wires under the dash that have ANY power are the two main RED wires that power the main on/off switch and the tach. I have checked the fuses under the seat but am at a complete loss now. I did have the stator apart but there were no issues...trigger coil is hooked up. Looking for some help with this havent rode this dang quad in over 2 years now. Thanks!
Bluewar02
CAN-AM (BRP) Ask an Expert!
Feb 20, 2016 07:03 PM
