300 bayou ball joint removal?
Old Aug 30, 2016 | 05:35 PM
Jugglethese's Avatar
Default 300 bayou ball joint removal?
It's a 1996 300 bayou 4x4 and I can't figure how to get the ball joint out or the bushings in the lower control arm
Old Aug 31, 2016 | 02:22 AM
Depends on what you are removing them for. Assuming the arm is scrap and you want to save the rubber bushes, saw through the steel tube they are pressed into. Avoid going too deep and cutting into the steel outer part of the bush. The ball joints usually press out after a circlip is removed, difficult from your photo, but I think the circlip has already gone.
jasarc
Aug 30, 2016 12:27 PM
russl
Aug 29, 2016 09:29 PM
rcappie4
Aug 27, 2016 06:09 PM
Leadfinger
Aug 18, 2016 02:15 PM
thippe
Aug 9, 2016 09:49 AM
