kodiak clutch kit
Old Apr 15, 2001 | 10:02 AM
ethomas's Avatar
I was told to get a kit for a grizzly with oversize tires for my 2000 kodiak i am planing on put 26 outlaws on it
Old Apr 16, 2001 | 10:43 AM
FKNA's Avatar
They make a clutch kit specifically for the Kodiak and it works well. I put one on after I put on 26" Mudrunners.
Old Apr 16, 2001 | 11:02 AM
kindsambo's Avatar
I'm only new and was wondering the purpose of a new clutch kit? Is it to generate more power because of the larger tire size? Will running a larger tire size burn up the factory clutch?
Old Apr 16, 2001 | 01:43 PM
FKNA's Avatar
Putting on larger tires will NOT burn up the factory clutch. What happens when you put on larger tires, the clutch doesn't engage quick enough which makes it harder to turn the tires. What the clutch kit does is make the clutch engage quicker, which in turn sends power down to the tires so they can be turned.
It is not neccessary to put on a clutch kit if you put on larger tires. But there will definitely be a noticeable difference if you do and well worth it.
buddieboy
Dec 9, 2016 05:50 PM
YankeeRebel
Oct 6, 2015 06:44 AM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
