Kawasaki bayou
Old Jan 18, 2017 | 10:24 AM
Woody2017's Avatar
Default Kawasaki bayou
I have a kawasaki 300 bayou that all it will do is idle I have rebuilt the carburetor and replaced fuel line and fuel filter set the valves and checked the timing on it all it will do is idle I have even replaced the carburetor with a new one and still only idle im running out of ideas is there anybody have the same problem with this thanks
Old Jan 18, 2017 | 05:28 PM
Atv dude's Avatar
[QUOTE=Woody2017;3349199]I have a kawasaki 300 bayou that all it will do is idle I have rebuilt the carburetor and replaced fuel line and fuel filter set the valves and checked the timing on it all it will do is idle I have even replaced the carburetor with a new one and still only idle im running out of ideas is there anybody have the same problem with this thanks[ does it cut off when you press gas
Old Jan 18, 2017 | 05:37 PM
Woody2017's Avatar
Yes it does
Old Jan 18, 2017 | 05:39 PM
Atv dude's Avatar
Check the gas and air mixture screw and does it idle hi
Old Jan 18, 2017 | 08:48 PM
Woody2017's Avatar
Yes I've tried that it still will die when u try to give it gas I've tried to choke it while it's idling it will die soon as u choke it
Old Jan 18, 2017 | 08:51 PM
Woody2017's Avatar
I took the air box off to see if it was pulling a vacuum I can put my hand over the carburetor and kill it it has a vacuum on it I ordered a new petcock valve going to try that
Old Mar 21, 2017 | 02:35 PM
Pyromaniac's Avatar
Woody 2017. Pyro here. Your float level adjustment in carb is too high, hence drowning piston in fuel.(dies)If you do not know how to adjust it, write me back and I will give you the correct measurement (float height) per my 220 service manual. What ambient temp are you trying at? Cold starting my 220 is nothing short of a bitch. If I use my choke @ all and try to give it fuel, it will stall unless completely warmed.
Old Mar 21, 2017 | 03:19 PM
Atv dude's Avatar
Default Bayou
how do you do that
Old Mar 21, 2017 | 08:54 PM
Pyromaniac's Avatar
Originally Posted by Atv dude
how do you do that
Remove your carb & remove 4 phillips screws @ the float bowl. Once the float bowl is removed, also remove the gasket as you are going to use this surface to place your tape measure. A vernier caliper would be better, if you own one.
From the top of the bowl surface, measure .860 to the top of the float.
That measurement is slightly under 13/16. Slightly means a gnat hair.
Hope this helps.
