Bayou 250 just clicks when I try to start it
Old Apr 10, 2017 | 11:47 PM
bikerider's Avatar
Default Bayou 250 just clicks when I try to start it
I have an 03 Bayou 250 that just clicks when I try to start it. The battery is good and the connections at the starter relay, battery and starter are tight. I cannot get it to start with the pull starter either. Any idea what is wrong?
Old Apr 11, 2017 | 12:15 PM
bikerider's Avatar
bump
Old Apr 12, 2017 | 02:13 AM
"I cannot get it to start with the pull starter either."
This throws your question too wide, if you pull and the engine spins but won't start, that is one thing but pull and the engine won't turn over, that is quite another.
To test the electric start I use a test lamp. Switch on, connect one wire to earth, t'other to the starter lead post on solenoid. Press start button, if the lamp lights but the motor doesn't turn, (assuming the engine isn't seized) you need to strip the starter, probably needs new brushes. If the lamp doesn't light but that solenoid clicks, you need a new solenoid.
Old Apr 12, 2017 | 09:56 AM
bikerider's Avatar
I should have been more clear. I cannot get it to start with the pull starter as well. The engine spins over just fine.
Old Apr 12, 2017 | 07:14 PM
bikerider's Avatar
An update: I can start the bike no problem with the pull starter. I tried bridging the two terminals on the solenoid and the green neutral light goes off and I get nothing while holding the start button.
Old Apr 14, 2017 | 02:31 AM
The starter may have an internal short, but it is most likely that either that battery isn't "good" or all connections are not "tight". Try jump leads to the battery and see if that makes any difference.
Old Apr 14, 2017 | 12:02 PM
bikerider's Avatar
I tried a direct wire from battery to starter positive terminal and nothing but I will try running that and a negative wire from the battery. The battery is new and good and all the connections have been checked and are tight.
Old Apr 14, 2017 | 12:53 PM
lciummo's Avatar
Measure the resistance with a meter between negative term on the battery and the negative starter terminal - should be a few ohms - less than 10. If it's open, check the ground strap from the engine to the chassis and from the battery neg to the frame.
The click elimnates the relays and the solenoid I think.
Good luck
Old May 4, 2017 | 11:40 PM
bikerider's Avatar
Good luck
What setting does my multi meter need to be on to do this?
I have replaced the starter relay and starter, made sure the fuse in the relay was good, cleaned the connections at the battery and ensured that the connections for the ground strap on the engine block and power wire to the starter are tight. I am still getting the exact same problem. Clicking when pushing the starter button and when I go to bridge the bolts on the relay I get the neutral light going out and nothing happening.
Old May 6, 2017 | 12:43 PM
BigWheelWade's Avatar
Have someone push the starter button and take a reading with your meter right at the starter motor. If the volts are too low to turn it over, then trace backwards to the relay, and so forth.
