01 honda foreman rubicon, electric start doesnt work
when I turn the key on the dash lights up, I hit the start buttom and the display disappears, no clicks or anything when I hit the start button, pull starts fine and runs but doesn't know what gear I'm in and the speedo doesn't work either, any help? ran fine when I took it to the woods, got back on and now it started doing all this
A bad connection between ignition circuit and battery, or a bad earth. It is probably going to be between the regulator and ignition fuse, if on the positive side. Could be the ignition switch, have you tried wiggling the key?
my battery reads 13.35V, it should be 13.0-13.2, that being said I put a battery charger on the battery still attatched to the quad and it started right up? is my battery bad then? now I'm really confused
Check that it is charging by putting the voltmeter across the battery when running, if it isn't over 13v and under 14.5v (should move about a bit as you increase revs) something is wrong.
Johnny821
Oct 22, 2016 09:11 PM
Aggie1127
Technical and How-To Articles
Oct 14, 2016 01:40 PM
