Bad starter
Well I got the my 4-wheeler running, but the starter wont turn at all.Brand new battery, yes it works becuase the lights and everything work when the 4-wheeler isnt on.I was just wondering can you rebuild the starter on a trail blazer.If so where is it located at(Ive looked and cant find it anywhere.Also if you cant rebuild it how much is a new one?
I feel your pain because I just had to rebuild mine. It is a bear to remove due to the back four bolt holding the starter. I used a long 10mm wrench with a 'customized' bend to get the rear bolts out. I put three back in but left the impossible bolt out. I also sealed my starter with silicone around the seals and on the bolts. It will cost around $50 for the brush set and the seals.
kbazzy
Sep 26, 2015 11:26 AM
