Dial-a-Jet
Old Oct 10, 1999 | 09:53 PM
Sburdman's Avatar
This is my other new toy. Anybody out there with any tips on how to set one up. The instructions are very thorough but it is always good to hear about personnal experience.
Scott.
Old Oct 16, 1999 | 10:56 PM
corncob2's Avatar
You should checkout snowmobile sites,some guy,s have had bad luck with them. COB
Old Oct 17, 1999 | 01:35 PM
bigdevil's Avatar
what is a dial-a-jet? i kind of get the picture just from the sound of it, but how does this actually work, and does it work well? i started to read a bit about jets, but i don't know a heck of alot about them. i put a pipe on my LT and never changed the jet, which i think i should have. how often do you change it? what i mean is, do you change it for winter, summer, humidity changes, altitudes? and how much does a difference does it make?
bigdevil '85 LT250r
Old Oct 17, 1999 | 03:52 PM
trx430ex's Avatar
Any minute now hot-shoe will strike and save the dayyyy!
I'm starting to figure out the skinny on this jetting stuff.But he explains it much better than i can.
Putting a less restrictive pipe on, Enables you to achieve a higher flow rate of air/fuel mix.Therefore you can add more fuel.And it can make a big difference.But tuning carbs is tricky bussiness.Do it wrong and you can burn down the motor.
Old Oct 17, 1999 | 05:00 PM
quad_man's Avatar
I found a lot of info here, and from the links off the site. Of course it's all the positive stuff about the dial-a-jet.
http://www.thunderproducts.com/daj.htm
Old Oct 17, 1999 | 06:58 PM
Sburdman's Avatar
TRX430EX,
Yes, you can burn your engine up if it is jetted improperly. A great way to do this is install an aftermarket pipe and not rejet.
Bigdevil,
I would recommend you pull your sparkplug and check the center insulator color. If it is white or light grey you could be headed down the road to trouble. Most manufactures jet a little on the rich side so you might be alright. Anytime you change the intake or exhaust on an engine it is prudent to check the jetting.
Here is a geat link to get the basics down on jetting and reading spark plugs.
http://www.motocross.com/motoprof/mo.../mototech.html
Rather than try to explain the Dial-a-jet it is easier to go to there website as listed in one of the other posts.
Scott.
Old Oct 17, 1999 | 08:38 PM
bigdevil's Avatar
i have checked my sparkplug. burns nice and tan. the only trouble i seem to be having is when i go to start the bike, it loads up, and floods the plug out alot. but i think this has nothing to do with the jet. i think i am having trouble with the floats sticking. i took the carb apart but didn't see any problem with the floats. checked the reeds too, but they look good. but if i leave it parked with the gas on, it drips out of the overflow. any suggestions, on what to check? no hole in the floats, and they aren't sticking
Old Oct 19, 1999 | 12:13 AM
corncob2's Avatar
Did you check the needle valve that runs the floats. COB
Old Oct 19, 1999 | 01:21 PM
Sburdman's Avatar
Corncob is right on the money. For clarity the floats forces the needle into it's seat shutting off fuel flow to the bowl when fuel raises to a predetermined level. If dirt/debris is interferring with a proper seat fuel continues to flow into the bowl. A bad needle or seat could cause this also. These needles do go bad over time.
Scott.
STLyamwar
Jul 25, 2020 04:44 AM
jnisson
Jun 14, 2004 07:21 PM
joequad
May 15, 2004 01:39 PM
Vforcer
Aug 8, 2003 01:41 AM
Oxygen
Feb 24, 2003 09:14 PM
