timing marks
Old Apr 17, 2001 | 04:34 PM
fix's Avatar
fix
I have a 1989 kawasaki bayou 300 4X4. I am rebuilding the top end of the motor. I need to know where the timing marks are on the cam shaft sprocket and on the fly wheel. I also need to know how to line them up.
Old Apr 17, 2001 | 11:17 PM
skidog's Avatar
remove the 2 black plug on the magneto cover on the left side of the bike,turn the engine until you will see a T mark on the flywheel,once this is set that will be your top dead center.then look at your timing gear on top and you will see a name like LF300 stamp on the outside of the gear,lign up that mark to match up the lign on the top of the casing,the mark LF300 should be at noon position.try that and you shouln`t have any problem.
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
