500 Polaris sportsman will not start
Old May 20, 2017 | 08:49 AM
Kernelcory's Avatar
Default 500 Polaris sportsman will not start
Thinking the battery was dead I charged it overnight but that did not solve the problem. With that I thought the battery would not hold a charge so I purchased a new one. Still will not start. I checked to see if I had lights with the new battery but did not. I suspect a fuse might be blown but don't know where to look. Is there an in-line fuse somewhere? Thanks in advance for any advise.
Old May 20, 2017 | 09:20 AM
Would help to know the year and model when posting.. Most of the older ones had a 20 amp circuit breaker in a plastic pouch located on the frame up from the battery. If you're not getting power on each side of the red wire,slice the pouch open and replace the breaker. You can get these at any auto supply.Later models have a fuse block withe separate fuses under the front panel.
Old May 21, 2017 | 08:25 AM
Kernelcory's Avatar
Thanks, old Polaris tech. I will look for the circuit breaker you mentioned. Your right I should have provided more information when asking a question. The machine is a 1999 Polaris 500 Sportsman. I have a couple of newer machines but prefer the 1999 when riding. I bought it new and it has been a reliable machine over the years.
Kernelcory
Old May 21, 2017 | 03:48 PM
Yep it has the enclosed circuit breaker. Some model pouches were located close to the left rear fender.
byronman
Nov 28, 2016 12:35 PM
ayn9465
Nov 27, 2016 02:48 AM
RobertLarabie
Oct 24, 2016 01:08 PM
Sarah Taegder
Sep 28, 2016 06:28 AM
cstark
Sep 11, 1999 01:21 AM
