My 2008 honda rancher shows just a dash where the gear display should be and wont sta
Old Jul 10, 2017 | 07:23 PM
Dale7107's Avatar
Default My 2008 honda rancher shows just a dash where the gear display should be and wont sta
my 2008 honda rancher shows just a dash where the gear display should be and won't start
Old Jul 11, 2017 | 02:42 AM
2008, that would make it a 420. A - indicates it is stuck between gears. As it will only start when in neutral (there is a lock-out that cuts power to the starter solenoid when not in neutral) the bike won't start until you change down/up into neutral. If the bike is changing gear, but the dash says it isn't, you have a fault in the rotary switch in the gearbox or it's wiring. If the bike won't change gear, it depends if it is ES or manual shift, if manual, a fault in the selector mechanism, if ES and you can't change with the "emergency lever" then it too is in the mechanism. If you can change with the lever, then a fault in the electrics, motor, angle sensor, switch buttons, wiring or ECU.
Old Jul 11, 2017 | 10:53 AM
Shelley-Ann LaMarche's Avatar
kids were playing with the throttle on trx honda 2006 and filled with gas and now it won't start. can someone tell me why it won't start?
jprancher
Jun 28, 2017 10:11 PM
spooled
Feb 16, 2017 06:39 PM
Bike pride
Nov 20, 2014 09:19 AM
cb2000warrior
Dec 4, 2002 09:14 PM
