no "4" on dash of rancher 4x4
Old Dec 3, 2002 | 07:33 PM
cb2000warrior's Avatar
Default no "4" on dash of rancher 4x4
my parents have a 2002 honda rancher es 4x4 nad this week end the number 4 wount show up all that it shows is a --. it shifts in fine and goes in to gear just fine. the display works good otherwise r-n-1-2-3-5 all work fine just not 4. i think it is a electral problem but dont know for sure. where is the plug for the tranie that tells the dash what gear it is in i think ill start there.
thanks for any help
chris
Old Dec 4, 2002 | 12:44 AM
KNOWSALOT's Avatar
The Facility
It's controlled by one switch. If the switch were faulty, it wouldn't work at all.
You have a blown bulb under the #4 lense.
The problem is that the ES models have a sealed instrument cluster that is not servicable. It's sold as one unit. Honda did this to make it waterproof.
Old Dec 4, 2002 | 08:03 PM
???? no lenes' on the rancher its a digtial number on a lcd screen when it should show "4" it just shows two dashes"--". my parents other quad is a recon and it has the lights across the top of the bash but not the rancher. any other ideas?
thank you again
chris
Old Dec 4, 2002 | 09:14 PM
03foreman's Avatar
It sounds like the shift position sensor needs to be adjusted, my foreman 450 does the same thing if you try to shift it when the motor is not running, because the gear does not fully engage and trip the sensor. Your transmision is fully engaging but the sensor does not detect it so it presents a -- on the LCD.
Your are correct cb2000 , it could not be a lens or bulb, the characters use the same LCD drivers and elements.
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
