2007 sportsman 500 drive belt????
Old Nov 8, 2017 | 12:47 PM
Whitetailhunter8955's Avatar
Default 2007 sportsman 500 drive belt????
Polaris website list 3 with different numbers. Based on the vin number. I have my vin number and can't figure out which one to go with.
Old Nov 8, 2017 | 12:58 PM
user493's Avatar
Moto Psycho
If I'm not mistaken part #3211077 is for several different models without EBS. The other 2 are for EBS clutches for sure. I would have thought the higher number is a replacement for the other, but if it was they shouldn't show the old number.
ETA: I took another look and it said that belt is used on 244 models. Part #3211113 isn't used on anything. That leaves part #3211091 for EBS.
Old Nov 8, 2017 | 01:15 PM
Um huh?? I am sorry but I have no idea what u just said?
Old Nov 8, 2017 | 01:45 PM
Look on the mfg build date sheet below your registration slip. You have the AZ model. All that means is body color which is Indy Red. Shows that you take the 3211077 non ebs belt. The Polaris Parts Catalog may help show things a little clearer on your model.http://parts.polarisind.com/Browse/Browse.asp If you do have the non ebs clutches,it's one of the few I've seen.Click on this link and then on the AZ driven clutch.http://parts.polarisind.com/Assemblies.asp
Old Nov 8, 2017 | 03:34 PM
user493's Avatar
Moto Psycho
I looked up the 3 belts for the 3 driven clutches you circled.
#3211077 is for non EBS for several different models of ATVs.
#3211113 was for EBS but not used on anything. Maybe replaced by #3211091?
#3211091 is for EBS.
There are only 2 belts available that might fit your ATV. One is for EBS and one is for non EBS.
Old Nov 8, 2017 | 04:37 PM
Seems to be a lot of confusion over this and even from some Polaris dealers. The 3211113 ebs belt is used on some 500/800 and other models and still available as shown on the Polaris Parts guide,but like this fellow found out 10 years ago when he posted on Polaris Riders that his dealers list was wrong.
"Belt Numbers from Polaris are wrong."
Well, went to buy a belt for the sportsman 800. Polaris was going to sell me the belt part# 3211106. This is the part number on their microphiche and all others that I looked at. They were out of stock, so I could not buy one. I decided to tear the belt off and take it to a few parts stores to match it up. Once I got the belt off I noticed it was a different number (3211113). I did some investigating and here is what I found - #3211106 - $88.19 is listed as stock belt for the 05 and 06 800EFI. It is NOT an EBS belt and cost much more than the actual belt. #3211113 is the belt that came off of my 800EFI. It is listed as an EBS belt and costs $60.89. So, for those of you who are going to buy replacement belts for the 800 EFI with EBS, save the almost $30 and get the belt that is for an EBS machine! Not sure if I am the only one that didnt know this or not, but at least now all of us here can save some cash."
People buying a used machine using a different belt may have a little problems on getting the right one if someone substituted belts. Polaris has a much longer list than this one from Partzilla and goes all the way to some 2017 and 2018 models also.https://www.partzilla.com/product/polaris/3211113
Here's the list from Polaris to make things even more interesting.Used on models other than the 2007 500 efi shown on Polaris Parts.
Usage : 3211113
Year Product Model Assembly
2018 ATV 570 SPORTSMAN 6X6 (R05) DRIVE TRAIN, SECONDARY CLUTCH - A18S6E57B1 (49ATVCLUTCHDRIVEN1323248)
2018 ATV 570 SPORTSMAN 6X6 TRACTOR (R06) DRIVE TRAIN, SECONDARY CLUTCH - A18S6S57C1/CL (49ATVCLUTCHDRIVEN1323248)
2018 ATV 450 SPORTSMAN HD 2x4 (R03) DRIVE TRAIN, SECONDARY CLUTCH - A18SAA50N5
2018 ATV SPORTSMAN TOURING 570 EFI/EPS (R05) DRIVE TRAIN, SECONDARY CLUTCH - A18SDA57B7/L7
2018 ATV SPORTSMAN 570 TOURING EPS EU (R03) DRIVE TRAIN, SECONDARY CLUTCH - A18SDA57F1 (49ATVCLUTCHDRIVEN11SP500)
2018 ATV SPORTSMAN TOURING 570 EFI/EPS (R05) DRIVE TRAIN, SECONDARY CLUTCH - A18SDE57B5 (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 570 TOURING EPS TRACTOR (R04) DRIVE TRAIN, SECONDARY CLUTCH - A18SDS57C5/E5 (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 450 HO (R03) DRIVE TRAIN, SECONDARY CLUTCH - A18SEA50B1/B5/SEE50B5/SEG50B8
2018 ATV SPORTSMAN 570 EFI (R05) DRIVE TRAIN, SECONDARY CLUTCH - A18SEA57B1/7/9/L2/L5/L7
2018 ATV SPORTSMAN 570 EPS EU (R04) DRIVE TRAIN, SECONDARY CLUTCH - A18SEA57F1 (49ATVCLUTCHDRIVEN11SP500)
2018 ATV SPORTSMAN 570 EFI (R05) DRIVE TRAIN, SECONDARY CLUTCH - A18SEE57B1/7/9/SEF57B4 (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 570 EPS EU (R04) DRIVE TRAIN, SECONDARY CLUTCH - A18SEE57F1/F7 (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 570 EFI HD (R03) DRIVE TRAIN, SECONDARY CLUTCH - A18SEF57N5 (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 570 EPS TRACTOR (R05) DRIVE TRAIN, SECONDARY CLUTCH - A18SES57C1/C2/C5/C7/E1/E5/E7 (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 570 EPS ZUG (R03) DRIVE TRAIN, SECONDARY CLUTCH - A18SES57F1/F7 (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 570 EPS TRACTOR (R05) DRIVE TRAIN, SECONDARY CLUTCH - A18SET57C1/C7/E1/E7 (49ATVCLUTCHDRIVEN11SP500)
2018 ATV SPORTSMAN 570 EPS ZUG (R03) DRIVE TRAIN, SECONDARY CLUTCH - A18SET57F1 (49ATVCLUTCHDRIVEN11SP500)
2018 ATV SPORTSMAN 570 SP (R05) DRIVE TRAIN, SECONDARY CLUTCH - A18SHD57B9/E57BB/E57BS (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 570 EPS EU SP (R03) DRIVE TRAIN, SECONDARY CLUTCH - A18SHE57FS (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 570 EPS TRACTOR SP (R03) DRIVE TRAIN, SECONDARY CLUTCH - A18SHS57CS/ES (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 570 EPS ZUG SP (R03) DRIVE TRAIN, SECONDARY CLUTCH - A18SHS57FS (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 570 SP TOURING (R04) DRIVE TRAIN, SECONDARY CLUTCH - A18SJE57BU (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 570 TOURING EPS TRACTOR SP (R03) DRIVE TRAIN, SECONDARY CLUTCH - A18SJS57CU (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 570 EFI UTE (R04) DRIVE TRAIN, SECONDARY CLUTCH - A18SUE57N5 (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 570 EFI X2 EPS (R05) DRIVE TRAIN, SECONDARY CLUTCH - A18SWE57B1 (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 570 X2 EPS EU (R04) DRIVE TRAIN, SECONDARY CLUTCH - A18SWE57F1 (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 570 X2 EPS TRACTOR (R04) DRIVE TRAIN, SECONDARY CLUTCH - A18SWS57C1/C2/E2 (49ATVCLUTCHDRIVEN1323248)
2018 ATV SPORTSMAN 570 TOURING EPS EU (R03) DRIVE TRAIN, SECONDARY CLUTCH -A18SDE57F1 (49ATVCLUTCHDRIVEN1323248)
2017 ATV 570 SPORTSMAN 6X6 (R10) DRIVE TRAIN, SECONDARY CLUTCH - A17S6E57A1
2017 ATV 570 SPORTSMAN 6X6 TRACTOR (R14) DRIVE TRAIN, SECONDARY CLUTCH - A17S6S57C1/CM
2017 ATV 450 FARMHAND HD 2x4 (R07) DRIVE TRAIN, SECONDARY CLUTCH - A17SAH50A5
2017 ATV SPORTSMAN TOURING 570 EFI/EPS (R11) DRIVE TRAIN, SECONDARY CLUTCH - A17SDA57A1/L2
2017 ATV SPORTSMAN TOURING 570 EFI/EPS (R11) DRIVE TRAIN, SECONDARY CLUTCH - A17SDE57A2
2017 ATV SPORTSMAN TOURING 570 EFI EPS MD (R05) DRIVE TRAIN, SECONDARY CLUTCH - A17SDE57N2/A57N2
2017 ATV SPORTSMAN 570 TOURING EPS TRACTOR (R08) DRIVE TRAIN, SECONDARY CLUTCH - A17SDS57C2/E2
2017 ATV SPORTSMAN 450 HO (R10) DRIVE TRAIN, SECONDARY CLUTCH - A17SEA50A1/A5/SEE50A1/SEG50A4
2017 ATV SPORTSMAN 570 EFI (R15) DRIVE TRAIN, SECONDARY CLUTCH - A17SEA57A1/5/7/9/L7/L8
2017 ATV SPORTSMAN 570 EPS EU (R04) DRIVE TRAIN, SECONDARY CLUTCH - A17SEA57F1/SEE57F1/F2 (49ATVCLUTCHDRIVEN11SP500)
2017 ATV SPORTSMAN 570/450 EFI MD (R06) DRIVE TRAIN, SECONDARY CLUTCH - A17SEA57N1/EE57N1
2017 ATV SPORTSMAN 570 EFI (R15) DRIVE TRAIN, SECONDARY CLUTCH - A17SEE57A1/7/9/F57A4
2017 ATV SPORTSMAN 570 EPS EU (R04) DRIVE TRAIN, SECONDARY CLUTCH - A17SEE57FL
2017 ATV SPORTSMAN 570/450 EFI MD (R06) DRIVE TRAIN, SECONDARY CLUTCH - A17SEE57NL
2017 ATV SPORTSMAN 570 EFI HD (R08) DRIVE TRAIN, SECONDARY CLUTCH - A17SEH57A7
2017 ATV SPORTSMAN 570 TRACTOR (R06) DRIVE TRAIN, SECONDARY CLUTCH - A17SES57C1/C2/C7/E1/E2/E7/SET57C1/C2/E1/E2
2017 ATV SPORTSMAN 570 TRACTOR (R06) DRIVE TRAIN, SECONDARY CLUTCH - A17SES57CL/EL
2017 ATV SPORTSMAN 570 EPS ZUG (R03) DRIVE TRAIN, SECONDARY CLUTCH - A17SES57F1/F2/SET57F1
2017 ATV SPORTSMAN 570 EPS ZUG (R03) DRIVE TRAIN, SECONDARY CLUTCH - A17SES57FL
2017 ATV SPORTSMAN 570 SP (R08) DRIVE TRAIN, SECONDARY CLUTCH - A17SHD57A9/AG/E57AS/E57AL
2017 ATV SPORTSMAN 570 SP TOURING (R08) DRIVE TRAIN, SECONDARY CLUTCH - A17SJE57AU
2017 ATV SPORTSMAN 570 EFI UTE (R11) DRIVE TRAIN, SECONDARY CLUTCH - A17SUH57N5 (100242)
Old Nov 8, 2017 | 04:55 PM
The belt that is on this machine was replaced 2 years ago by a polaris dealer. I am going to take it apart to see what the number is. Weird thing is this belt only has about 80 hours of run time on it and it is destroyed... if they put the wrong belt on it, could that be why it failed prematurely?
Old Nov 8, 2017 | 05:08 PM
Possible because it was the wrong belt,BUT first off do you have the ebs or non ebs clutches or do you know? This can help narrow it down a bit.
Old Nov 8, 2017 | 06:19 PM
when I click on the bottom link It won't go through. But I do know when I go down hill with my 98 I can feather the gas and the motor holds me back. On this one how ever the motor does not hold me back. I have to use my brakes all the way down the hill. But if they put the wrong belt on??
Old Nov 8, 2017 | 06:29 PM
Your 98 had non ebs clutches and used the 3211077 belt. Ebs clutches really stared kicking off on 2000 models. Just look at your drive clutch and see if you have the one with the one way bearing(item#1) like in the top pic or the non ebs clutch in the bottom pic. Both were available that year.
