03 350 es 4x4 ignition fuse
Old Nov 14, 2017 | 07:18 PM
Shrydo's Avatar
Default 03 350 es 4x4 ignition fuse
Just bought an 03 honda rancher 350 es all time 4x4. Put a new carb on and it fired right up for maybe 10 seconds then died and wouldnt start. Found a blown ignition fuse. Looked for shorts, couldnt find any. Only blows after starting(starter or pull rope). But will start and run with battery unhooked. Thats where i get lost lol. Help would be much appreciated.
Old Nov 15, 2017 | 02:49 AM
Seems a lot like a CDI problem, but will be difficult to trace in order to check for sure. I would first find out what voltage the regulator is putting into the battery if possible, anything over 15v is going to mess the system up. Connecting a high current ammeter across the ignition fuse socket, then disconnecting things like the CDI, dashboard plug and LH switch box plug, may indicate where the high current drain is coming from.
Stumped62
Nov 28, 2016 06:55 PM
qwhacker
Technical and How-To Articles
Nov 23, 2016 05:43 AM
kiamquad
1) Engine problems..
Oct 8, 2016 06:16 PM
BigRed450
Jun 29, 2000 12:21 AM
