2005 Honda Rancher AT question about auto shift mode
Old Jan 26, 2018 | 09:45 PM
lph008's Avatar
Default 2005 Honda Rancher AT question about auto shift mode not working and esp blinking
Question regarding the automatic transmission mode not working on 05 rancher 400. It had the selectable automatic mode or the electronic shift mode. Auto mode doesn't work but electronic shift does?? I've done some research and some guys say it is the angle sensor but none of them confirmed whether or not it fixed the issue. I'm going to look at this quad tomorrow to buy. Was just hoping someone could shed some light on what else it could be that I could look at or check while I'm there. I'd hate to throw expensive electrical sensors at it for nothing. He said sometimes auto will work for a second then it will stop and esp will blink and he will have to shut it off to go back into esp Thanks for the help
Old Jan 27, 2018 | 03:00 AM
Unlikely to be the angle sensor. Possibly the switch between auto and ESP, but that blinking on the dash is Morse code which, in theory, tells a Honda technician where the fault is.
Old Jan 27, 2018 | 07:13 AM
lph008's Avatar
he also said that when it started happening, it would have issues in reverse both auto and esp. It would just bog down when you put it in reverse so he said he changed the reverse sensor (not sure of the proper term for the sensor ) but it didn't fix that issue. While doing so he found that if he left that sensor unplugged then reverse works fine.
so he just left the "reverse sensor" unplugged and rode it.
I asked him if he checked for codes and he hasn't, he didn't seem to know that you could. It's only 10 min away from me so it can't hurt to go look at it. If it's beat I'll walk. I haven't owned a honda quad in quite a while. I know a good amount about polaris sportsman but I know nothing to look for in the Honda's. Problem areas.
Old May 14, 2020 | 09:48 AM
Tiger-64's Avatar
Got the same problem , did you find the cause of it
Old May 22, 2020 | 02:41 AM
If you leave a sensor unplugged, the computer recognises it as a fault, throws a fault code up, and usually stops working until you switch off and switch back on again. Check what the fault code is, probably so many long, then so many short flashes, repeated.
Old May 22, 2020 | 09:10 AM
Tiger-64's Avatar
Flashes 12 times
tony cub
May 29, 2020 01:45 PM
Frogger1
Nov 13, 2010 10:16 AM
forgepro
Dec 28, 2008 10:29 PM
neilo
Sep 7, 2008 08:50 PM
lucleb
Dec 17, 2007 12:27 PM
