water pump shaft
Old Jan 30, 2018 | 01:52 PM
case19's Avatar
Question water pump shaft
i have 2 Polaris quads one is a 2001 sportsman 400 the other a 2001 sportsman 500 parts quad. The 400 has been having bad cooling issues i narrowed it down to the water pump and its seals shortly after pulling the seals and putting the new ones back in i pulled the rope and the shaft had looked like it had a wobble in it. My question is, can i take the water pump shaft out of the 500 parts quad and put it in my 400 and it do the job and what would it take to do so
Old Jan 30, 2018 | 04:41 PM
It takes splitting the engine to replace the oil pump/water pump shaft. Cheaper in cost and labor to just buy a new one for 40 bucks. If you have to pull a water pump seal again,let a dealer do it or invest in the right tool to keep from bending the shaft. Having it stripped down,ready to pull,most dealers won't charge that much to pull the seal. I pulled plenty of seals for people along with splitting engines for people that pried them out and bent shafts. https://www.ebay.com/itm/Polaris-287...1Z73lW&vxp=mtr Both shafts in the 400,500 are the same..
Attached Thumbnails water pump shaft-4e2cc3ac70e31f19343cd3dfe35c7d42e44e7bce.png   water pump shaft-s-l500.jpg
Old Jan 30, 2018 | 04:52 PM
case19's Avatar
Ok thank you. im trying to do it quick i have done all of my own repairs on these quads so i know them pretty well , what all do you know about doing a complete engine swap putting a 500 in a 400 frame and electronics is that possible
Old Jan 30, 2018 | 05:06 PM
Crankshaft assembly,rods,plus obviously the pistons and cylinders,heads show different part #'s on the 500 versus the 400. More logical to just fix the 400 if the shaft is the only thing wrong with it..
Old Jan 30, 2018 | 05:16 PM
case19's Avatar
great thank you tons, i will get started on that all ASAP
Old Feb 5, 2018 | 12:44 PM
case19's Avatar
So chances are I’m gonna have to buy all new gaskets for the rebuild or can I get a tube of gasket maker and use it and it still hold up and last as good
Old Feb 5, 2018 | 01:10 PM
New gasket on the water pump cover at least.Plus if mine I'd go ahead and replace the w/p seal again along with the oil seal since you'd have the engine apart. Cam cover gasket if not damaged can be used again with a film of gasket maker. Use Threebond,Yamabond,or similar type engine sealer such as Permatex Grey for this and the engine cases.https://www.permatex.com/products/un...et-maker-grey/
mikesjunk
Jan 3, 2016 07:16 PM
mjreese
Sep 5, 2007 04:19 PM
DuneMe
Mar 5, 2004 11:32 AM
Hightower
Jul 2, 2002 06:39 PM
