polaris 400 xplorer water pump, pump shaft
Old Jun 24, 2007 | 10:00 PM
mjreese's Avatar
Default polaris 400 xplorer water pump, pump shaft
I have a 2000 polaris 400 xplorer. Water pump was leaking took pump off. The shaft where the pump goes on has grooves in it. Is this the way it should be?
Old Sep 5, 2007 | 04:19 PM
MNupNorth's Avatar
It should be smooth as a babys bottom. If you've got grooves the seals will just keep getting wrecked. Not a cheap fix though. If the grooves a minor and you put some new seals in you might be o.k. for a little while.
KimSJoh
14
Jul 18, 2015 07:20 PM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
