spun bearing fix? worn case half pto side
ok, so im in the middle of this build and I want to know what the best method of fixing this problem is aside from getting a new case. Both pto bearings spun in the case. there is a definite ridge between the bearing seats (where the outer races are supposed to interfere with the case.) I know there are several methods of fixing this. , ie peaning the surface, locktight, sleave retainer. or just slam it back together and hope for the best. What should i opt for "OPT"? what would you do in this situation?
if i pean it and lock tight it i think ill be ok, as long as the center line on the crank stays true. This really wasnt evident untill i washed the **** out of the case halves.
duneittilludie
Feb 26, 2003 06:42 PM
