why wont my 300 ex start when i hit the button??
Old Mar 15, 2018 | 06:59 PM
JacobRoof56's Avatar
Default why wont my 300 ex start when i hit the button??
hello I have a 300ex that I just recently rebuilt. now it is time for wiring and starting. the motor will not turn over or do anything when I hit the start button any help appreciated thanks.
Old Jul 17, 2018 | 01:29 PM
IB Cheryl's Avatar
IB Staff
Hi, I moved your thread to the Honda forum. Hope your question gets answered there. Thanks!
Old Jul 18, 2018 | 01:57 AM
Generic how to test a starter circuit. Make sure the battery is charged and the connectors clean and tight. Does the solenoid click? If no, disconnect the two thin wires to the solenoid where they plug into the loom, put a 12v test lamp across the loom side plug, switch on, press start button, does the lamp light brightly? If yes, you have a faulty solenoid. If no, connect one wire of lamp to earth the other to the yellow/red wire on that plug, press start button again, if it lights, you have a faulty earth lead to solenoid. Fairly complex on most Hondas as the neutral light circuit is often wired to it, but you just have to trace through the system to find the fault.
JacobRoof56
Jun 4, 2018 05:38 PM
chefph@aol
1) Engine problems..
22
Jul 1, 2013 10:01 AM
raptorider
Oct 8, 2008 05:14 PM
whitebread
Aug 20, 2003 11:13 AM
