2001 Suzuki KQ 300 shaft problem
Old Apr 14, 2018 | 03:44 PM
Domi1983's Avatar
Default 2001 Suzuki KQ 300 shaft problem
I have a 2001 Suzuki KQ 300. I'm having a problem with one of the shafts, that come off the rear end. Last year one twisted off at the U joint. I bought a new shaft, with U joints and installed. This year it did it again same side. What's the problem? Also noticed it seems like my rim is warped. But it seem to eat shafts all of sudden?
Old Apr 15, 2018 | 02:27 AM
Did you buy a genuine shaft? I repaired one with a "UJ kit" and noticed the spider part was thinner than the original, but the cups were right. Lasted about 12 months before it broke and I had to buy a very expensive genuine shaft assembly.
Old Apr 15, 2018 | 07:14 AM
Domi1983's Avatar
Yes, I bought a suzuki shaft it cost me $400. I should mention that my tires were frozen as well. So I wonder if that is what caused it break.
Old Apr 16, 2018 | 01:30 AM
Where did it break? The usual, is the UJ bearings get worn, the spider then breaks out of a yoke and chews both yokes up. Worn splines is lack of lubrication, usually because the rubber boot has gone and dirt/water got in.
Old Apr 16, 2018 | 01:53 PM
Domi1983's Avatar
It broke right at the U joint, so not sure if the U joint itself was junk. I will be tearing it apart on Wednesday. Will post pictures for you to see
Old Apr 19, 2018 | 01:49 AM
biz4two's Avatar
Arrow
Hmmm, I'm interested to see how it broke??
biz
Old Apr 20, 2018 | 10:37 AM
Domi1983's Avatar
Old Apr 20, 2018 | 10:39 AM
Domi1983's Avatar
Same place the original broke last year. I noticed there was a lot of ice build up, so that would explain for the freezing. The bearings seem fine no play in them. I will have to buy another one and clean all the hubs since there was ice in one.
Old Apr 21, 2018 | 07:11 AM
Just a thought, Suzuki usually equipped the UJs with rubber covers. In fact there was a recent post on here asking if it mattered that the boot had split. Consensus was that it didn't matter, but I wonder if some snow, which then froze, got into the yoke and jammed the spider, a bit unlikely, but Suzuki fitted those boots for some reason.
Old Apr 23, 2018 | 06:34 AM
Domi1983's Avatar
I have the boot on mine, not really sure why it broke. but on the hunt for a new one. Local Suzuki dealer here wants $550 for a new, I paid that last year for that shaft so now thinking of getting a used one to see.
mikesjunk
Jan 3, 2016 07:16 PM
aaronrkelly
Jan 8, 2010 10:14 AM
map351
Mar 31, 2008 12:56 AM
