85 Suzuki 230 shaft drive problem
Old Mar 29, 2008 | 05:49 PM
map351's Avatar
Default 85 Suzuki 230 shaft drive problem
Hi All
Need a little help with a 85 Suzuki 230 shaft drive. Is there a check valve for the trans/crankcase breather? I getting a lot of oil in the air box (1 pint) also out the long vent up by the bars. I checked the fill level line on the right case wasn't over filled. Hope it doesn't have a broken ring? Seams lazy too like timing is not advancing?
But it starts right up on the electric & pull.
Mike
Old Mar 30, 2008 | 01:51 PM
JustRandy's Avatar
The CDI controls the ignition timing, so there is no way for that to be off or not advance. The pickup coil tells the cdi when TDC is and the cdi makes the decision when to send out a spark.
You have bad rings and are probably not too hard to find in the trails..... Just follow the white cloud. [img]i/expressions/face-icon-small-happy.gif[/img] The rings are allowing blowby to force oil up the breather tubes. Like you said, the rings may even be broken. A bore job with piston will probably set you back around $250.
I don't know anything about a check valve in the breather. Never heard of that before.
Old Mar 30, 2008 | 02:40 PM
map351's Avatar
Thanks Randy
I found the problem, As i said i just bought this 230 from a guy that couldn't keep it running and no power. I was mistaken of the oil level, there was just about 4 Qt's of Gear oil (90W) in the crank case! I drained the case changed oil filter added 1500CC and it fixed all the problems.
Now it pulls hard and the air box is dry.
Mike
Old Mar 30, 2008 | 03:08 PM
JustRandy's Avatar
I was wondering,,, but you said the oil was right. Good you found the problem.
Old Mar 30, 2008 | 03:15 PM
map351's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: JustRandy
I was wondering,,, but you said the oil was right. Good you found the problem.</end quote></div>
But the wrong weight (90) Gear oil. It calls for 10/30 SAE..
Old Mar 30, 2008 | 11:59 PM
JustRandy's Avatar
10w40 usually goes in them. The old stuff too, not the new car oils with additives. Type F, G or older I think. The new stuff will make your clutch slip.
Old Mar 31, 2008 | 12:36 AM
map351's Avatar
Randy i use Amsoil SAE 10W-40 Synthetic in all my Bikes & quads, even in my Old Ossa GP3 Phantom..
http://www.amsoil.com/StoreFront/mcf.aspx
Old Mar 31, 2008 | 12:56 AM
JustRandy's Avatar
Ok... I was just saying in case you didn't know.
I use the cheap stuff and change it regularly to get the metal particles out and install a new filter. Synthetic is rich man's oil. [img]i/expressions/face-icon-small-wink.gif[/img]
jayking232003
Dec 4, 2019 09:38 AM
txkevin
Sep 21, 2015 02:02 PM
volsgo30
Jun 4, 2015 06:07 PM
kevbowe
Jun 1, 2015 01:17 AM
exmxer
Dec 7, 2000 01:29 PM
