Trx 200
Not sure of the year but it's shaft drive which I read are early models. I got it as part of a package deal, not familiar with them. It just needs a stator as far as I know but I'm having trouble getting the wood ruff key and flywheel back on. Any tips/ideas?
If the crankshaft keyway is a bit worn the key has a tendancy to slide out when you shove the flywheel on but if you set it so the key is at a slightly bigger angle than the crank taper, the flywheel should slide over then shove the back end of the key down as it goes. As far as I know, the shaft drive Big Red three wheeler was 84 to 86 and the four wheeler 86 only.
TimberedWolf250
ATC 3-Wheelers
Nov 11, 2007 10:56 PM
