polaris awd coil
Old Jun 3, 2018 | 08:42 PM
will_puckett's Avatar
Default polaris awd coil
I've had issues with my 97 Polaris 500 xplorer AWD system. right side engages but left side doesn't. instead of dropping $150 on a new coil and sleeve I found a used replacement strut for $60. That fixed my issue for about 5 months. now i'm having the same issue again. I tore down the hub system and found that my magnet does energize and pull the armature plate to the magnet but I can pry it off slightly easier than I can on the side that works. I'm tired of messing with this issue and since I use my machine almost exclusively for mudding I need my AWD system to be reliable. I just want to be positive i'm not missing anything before I drop the cash on the new magnet. anything I could be missing? could there be an electrical issue that is causing only the left side magnet to burn out?
trbojet1
Oct 12, 2017 04:33 PM
moocowman
Oct 8, 2017 02:41 AM
TLC
Apr 25, 2007 05:38 PM
rockinrodtex
Mar 21, 2007 11:56 AM
Banshee2001BW
Sep 28, 2005 09:45 AM
