CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
Ds650 starting problems
Old Jun 24, 2018 | 05:23 PM
Stump1013's Avatar
Default Ds650 starting problems
Ok guys needs some help here ready to set this thing on fire..thing would never start valves were tight i adjusted the calves to correct shims on intake n exhaust have plenty of clearance in between cam lobes n shims..problem is i done set tdc about 10 times now its dead on..will not fire one hiccup sprayed gas into carb while cranking n while not all it does is make a loud backfire n some flames come out. Its like valves are tight but there not.idk how it could be firing wrong with it at tdc. I need help asap carn is clean have plenty of spark bright blue.
gomer4877
Aug 7, 2014 09:34 PM
Polaristrailboss350
Mar 21, 2013 12:47 AM
popsynth
May 28, 2010 12:24 PM
mcdonl
Sep 9, 2009 05:05 AM
killme2
Sep 26, 2004 02:57 PM
