400e keeps stalling... help?
Old Jul 13, 2018 | 04:07 PM
jflitsch22's Avatar
Default 400e keeps stalling... help?
Just changed my clutch with a tusk clutch in my 400ex... put it all back together and now it stalls when I put it in first. Replaced the cable and still stalls. Any ideas?
Old Jul 16, 2018 | 08:28 AM
DirtDevil101's Avatar
Yes...you didn't re-install it correctly or the new cable is not adjusted correctly...pull the cover and observe how much movement when you pull the clutch...there should be 1/4" or so...if little or none then the something is not quite right. Sometimes the clutch cover requires a new OEM gasket...if you used gasket maker that could also cause it not to disengage enough to slip it into gear...
400EXGuy070
Jun 1, 2006 10:19 PM
MHull
May 9, 2005 12:45 PM
bgdggr1
Jul 15, 2004 03:28 PM
nostradamus2001
Nov 17, 2002 02:02 PM
Toaster
Mar 15, 2002 10:57 AM
