keeps stalling
Old Nov 15, 2002 | 05:29 PM
nostradamus2001's Avatar
Default keeps stalling
My lt bogged down and stalled about a week ago and i was lookin at it and readin my manual and stuff like that and i thought that it might be my coil due to the fact that i put a new stator in and maybe it couldnt handle the charge but come to find out no that wasnt it , it just stalled again today im think it might be my carb any suggestions???
Old Nov 15, 2002 | 05:44 PM
just a thought, when i first left i let my quad warm up alot and it ran fine then i stopped to hang with some friends and when i left from there and i didnt let it warm up long at all , is it maybe stalling due to that??
Old Nov 15, 2002 | 11:13 PM
LT250RSuperstar's Avatar
I would say it is cold seizure but your engine didn't take a piston and/or lock-up. It still runs right?, What does your sparkplug look like?
Old Nov 15, 2002 | 11:41 PM
it runs after a bunch of adjustments and then after about an hour of riding it stalls and fouls the plug and when i put a new plug in after it stalls it still wont start i think its my carb
Old Nov 16, 2002 | 12:28 AM
What are those adjustments your talking about? and what is your fuel mixture?
Old Nov 16, 2002 | 12:54 AM
ecorman1's Avatar
I didn't notice what Suzuki you have but you can check a few things. It sounds like your fuel isn't getting to the chamber as you described. Make sure your fuel valve is turned to "ON", not "RESERVE". Since it sounds like you're flooding the chamber, next you should check the float in the carburetor. If the float is stuck in the bottom of the carb, it makes the engine run rich. The quad may start easy at times but stall after.
Do one test at a time and good luck.
Chuck
Old Nov 16, 2002 | 11:05 AM
once it stalled we messed with the air adjustment screw and idle and we got it running again but after about an hour it just stalled again
Old Nov 16, 2002 | 11:31 AM
DON'T mess with the air screw!!, your just lookin for trouble then, cause #1 if you screw it out too much you are either gonna run your quad way lean and score you cylinder walls OR put a hole in your piston! #2 if you put it in all the way its flood itself and not run at all or very little.
First put the airscrew adjustment to its original setting and try ecorman 1s options.
Good luck!!
Old Nov 16, 2002 | 02:16 PM
i had to mess with the screw cuz it fell out when i first got the quad and ive already dont all of these things but thanks anyways
Old Nov 17, 2002 | 02:02 PM
Bom2000's Avatar
I think its your carb. The float bowl is sticking. That should be the problem because if you replaced the coil and the stator I wouldn't know what else it would be.
Pehter
Oct 3, 2024 11:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
nastyblaster100
Sep 13, 2015 01:19 PM
