1986 polaris trail boss 250
Old Aug 25, 2018 | 04:22 PM
143's Avatar
143
Default 1986 polaris trail boss 250
I accidentally put oil in the side plug by the pull start. Is this bad? Can I drain it or should I drain?
what kind of oil do I need.
Old Aug 25, 2018 | 05:21 PM
143's Avatar
143
I put oil in the hole next to the pull start thinking it needed oil. Realized that 2 cycle doesn't need oil. What do I need to do to drain that oil out? Does a 2 stroke need engine oil?
Old Aug 27, 2018 | 02:49 AM
We have the answer to your question on the ATV Connection homepage, here:
https://atvconnection.com/articles/a...oes-my-oil-go/
Old Aug 27, 2018 | 06:12 AM
Drosner's Avatar
Which hole are you talking? Can u send a picture?
this model has an oil tank near the gas assembly and it automaticall6 premixes the oil with the gas. With a 2 stroke you mix oil and gas to get oil to the engine. Check this or another forum for the Polaris service manual and it’ll explain.
btw - if you got this bike from someone ask them if they bypassed th3 oil injection. Some people d9nt like the auto mix and shut it off and mix oil and gas in the tank...
Old Aug 27, 2018 | 07:09 AM
143's Avatar
143
Default Oil pump
The polaris guys answered my question. As far as the oil pump, it looks like they capped off the line for it. I guess I have to mix it myself. I dont know who previous owner was. Also wanted to see if you knew a place or website to get cheap parts. I've tried local junk yards but nobody around here has any for that year. Also tried Ebay but some people want a lot for old parts. Thanks for your help. By the way that hole I put oil in was for the crank case where the pull start is. They told me just to loosen bolts and drain.
Old Aug 27, 2018 | 12:40 PM
Drosner's Avatar
I get most of my 1986 parts from BikeBandit.com - only a few places have the 1986 parts. For the more common stuff or after market eBay or even Amazon worked for me. In some cases you'll find that the 1986 OEM part just isn't available anywhere. In that case your only chance is to find something used on eBay...
Good luck - i'm restoring a '86 myself....
Old Sep 4, 2018 | 08:10 AM
143's Avatar
143
Default Transmission
Thanks and same to you.
by the way, I bought a transmission from Ebay and wasnt sure of the fit so when I got it the bolt pattern seemed to match up. My question is, will any transmission work as long as I can match the bolts up?
metsfan1231
Jan 10, 2019 02:07 PM
Bear1959
Jun 29, 2008 10:59 PM
Bear1959
Jun 20, 2008 12:05 AM
Bear1959
Jun 17, 2008 02:17 PM
Templar16
Nov 16, 2000 03:12 AM
