1989 trx300
Old Sep 3, 2018 | 04:51 PM
Stubby43's Avatar
Default 1989 trx300
Really wierd Problem. Battery fully charged neutral light comes on front headlight comes on starts just fine. Ride for five minutes or five hours no difference when I shut it down it will not start no neutral light no front headlight Drag it back to the house hook up the charger and the neutral light comes on immediately and it starts just fine I am really at a loss
Old Sep 4, 2018 | 02:14 AM
Probably a loose or corroded battery terminal, when you hook up the charger, you move it. Can be at either end of the wire, so bad earth or loose solenoid terminal, or even faulty fuse.
Old Sep 4, 2018 | 08:19 AM
Stubby43's Avatar
Battery connections are good, clean, and tight. Will check the other end and the fuse. Was reading through the repair manual and faulty fuse could be the problem. Very aggravating
Old Sep 4, 2018 | 08:09 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Check red connector in front batt, to see if has bad red or green in it this could cause your problem
Old Sep 4, 2018 | 11:11 PM
LT80's Avatar
LT80 Expert
Good to see ya papa.
Old Sep 5, 2018 | 07:44 PM
Loved
Community Favorite
Thanks LT80 Been under weather glad to be back
Tstarkes
Nov 10, 2015 07:42 AM
Mojaveman48
Jun 1, 2014 02:15 PM
dsc355
Oct 18, 2007 09:39 AM
JJdynomite
Apr 2, 2000 12:02 AM
drlaney
Sep 23, 1999 05:15 PM
