Honda ATC90 Front tire question
Old Sep 14, 2018 | 11:26 AM
BMW1's Avatar
Default Honda ATC90 Front tire question
I have a atc90 and the frame says US90.
I think this may have originally had the balloon tires but someone converted to have all 22x11x8 knobbies.
The existing knobby front tire is shot - 22x11x8.
I cut the tire off and noticed there are what looks like two large o rings or gaskets next to the bead on each side and it does not look like this rim can be split. The front rim has a 3 bolt pattern. There are no other bolts in the front rim. Do these rims require a special tire or do you change them like a normal tire? Are there any special procedures for install the new tire?
The rear wheels are split rims. I have fixed one of the seals between the split rims on the rear, so I know those are split rims.
Old Sep 14, 2018 | 05:21 PM
BMW1's Avatar
Here are pictures.
Old Sep 24, 2018 | 03:00 AM
We've got your hookup right on the ATV Connection homepage, which can be found directly here:
https://atvconnection.com/articles/a...ock-split-rim/
Old Sep 24, 2018 | 06:16 PM
BMW1's Avatar
thank you for the reply. I replaced the tire with a 22x11x8 knobby tire and it seems to be just fine.
Appreciate the help.
trucker2565
Aug 15, 2016 10:41 AM
cornermike
Aug 13, 2016 09:33 PM
zanerojo
Aug 10, 2016 11:29 AM
atom0s
Jul 22, 2016 01:54 AM
lovinhonda
Jan 25, 2000 09:17 PM
