2012 recon ES.
Old Sep 21, 2018 | 09:38 PM
Tim Bryant's Avatar
Default 2012 recon ES.
5th gear light on, no electric start.
1st gear light flashes 6 times, repeats until cleared, starts again.
that code is failsafe relay. Would that make it stick in 5th?
TIA,
Old Oct 4, 2018 | 05:49 PM
Stephen01's Avatar
Is it electric shift? Because I had a problem with my rancher electric shift to neutral light will blink five times and it turned out to be a blown fuse.
Old Oct 5, 2018 | 02:16 AM
Not sure what code 6 is on a recon, but thew first thing to do is change down to neutral with the emergency lever. Once the neutral light is on, you should get the electric start back. If you can't get it to change with the emergency lever (it will be stiff) you have a mechanical problem with the selector mechanism. Most electrical problems with the ES system are faulty angle sensor (but that is code 3 on most Honda ES) or faulty shift motor, (brushes worn or magnets dropped off).
ATV Connection Reporter
Feb 27, 2012 05:17 PM
sportszillasheex
Feb 11, 2011 07:19 AM
reliv007
Jan 25, 2005 03:22 AM
shotguncreek
Jan 17, 2002 07:42 PM
pyromaniac442
Nov 25, 2000 01:03 PM
