baja 90 stator help
Old Oct 29, 2018 | 10:37 PM
v.i-guy's Avatar
Default baja 90 stator help
hi everyone I picked up a older Baja 90 cc with stator problems here is a pic of stator its a 7 winding the only replacement I can find for it is from here and they are out of stock https://www.chinapartsdepot.com/shop...exd.asp?id=749 I see lots 0f 6 winding stators are interchangeable or is there someway to put a aftermarket pickup on the quad thanks
Old Oct 30, 2018 | 02:07 PM
v.i-guy's Avatar
sorry I meant to say are the 6 winding stators interchangeable with one I have or do I have to find the same stator to make it work. or is there some other way to make it work its just the pickup that doesn't work on the stator thanks
Old Oct 31, 2018 | 03:41 AM
By "pickup" are you referring to the coil that goes on the outside of the flywheel? I suspect this trigger coil will be the same on most Honda clone motors, so would take one off the cheapest 6 pole stator I could find, and solder it to your stator blue/white wire. Check it's mountings are the same, and that it doesn't hit the pip on the flywheel.
Old Oct 31, 2018 | 02:11 PM
v.i-guy's Avatar
no sorry I should have said source coil there is a coil on the stator that is a bigger coil then the rest with epoxy on it.it is wrapped with smaller gauged wire than the rest on the stator . I get 0 reading with a omhs meter when I test it and I can see where the stator bolts must have come loose and it rubbed against flywheel and broke some wires on it the rest of the stator is fine..i have read online but cant see what this coil does and can it be bypassed or do I have to find a stator that will fit thanks.
Old Oct 31, 2018 | 04:01 PM
v.i-guy's Avatar
ok I found out what the winding is called that is damaged its called the exciter coil and I take it this sends a signal to the the cdi to produce spark to the spark plug. but I take it. it is also part of the charging system .
Old Nov 1, 2018 | 03:26 AM
There are stator re-winders that can do it for you. We often get Honda etc, stators re-wound. It will be more expensive than a Chinese 6 coil stator though. The exciter provides the power to the CDI, the trigger coil provides the timing.
Old May 30, 2021 | 02:57 PM
Balentor's Avatar
Default 7 pole stator
Hello, did you ever get this figured out? I have the same exact problem. Did you try the 6 pole?
dave
Ronj1977
1) Engine problems..
10
Feb 24, 2015 05:11 PM
beyondupnorth
May 11, 2011 11:47 PM
NovaLT250R
Mar 25, 2004 08:33 PM
NovaLT250R
Jan 15, 2004 02:29 PM
