No spark
Old Dec 9, 2018 | 08:38 AM
ATV2018's Avatar
Default No spark
1987 Honda trx 350d Fourtrax Foreman with no spark.. A friend acquired this foreman which has been sitting about 10 years unused. the ignition coil reads .2 ohms on the primary side and 8.5 ohms on the secondary. The pulse generator has 311 ohms. The gearshift in neutral has continuity. The ignition and stop switch has no continuity when in the on position. All readings taken at the harness at the CDI. All readings were good according to the service manual so assumed the CDI was bad and replaced. However still no fire. Bought a peak voltage adapter and checked out put of the pulse generator which is 6 volts. Is this a good reading? No spec. for this in the manual. Another bit of information, The old CDI would allow the fuel pump to run if the Bl/Y wire was removed from the primary side of the ignition coil but the new CDI does not do this. Any advice would be appreciated.
Old Dec 10, 2018 | 03:28 AM
I think 6v from the trigger will be enough. I only ever did one 350D and fitting a used CDI got it going again, not even sure if it is AC or DC ignition, (the 1980s 250 was AC and the 300 DC). Main thing is, are you getting a full 12v from the ignition if it is DC, or plenty of volts from the alternator exciter if it is AC? Also most important, is the earth lead to the CDI earthed? Sorry I can't be more help.
Old Dec 10, 2018 | 04:18 AM
ATV2018's Avatar
It is DC ignition and has full battery voltage (12.6V) at the CDI and we do have a good ground. Also I meant to say 8.5K ohms for the secondary side of the ignition coil in my original post. If 6 volts from the pulse generator is good then I am beginning to wonder if the new CDI is bad however unlikely that may be.
Old Dec 10, 2018 | 08:55 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Just make sure the CDI box is for the trx350 D model [foreman] Honda also made an 1987 trx350 [fourtrax] and these CDI are not interchangable
Old Dec 10, 2018 | 08:59 PM
Loved
Community Favorite
Also the Trx350D has fuel gauge in right front fender and fourtrax doesnt
Old Dec 17, 2018 | 08:24 AM
ATV2018's Avatar
After re-checking everything that I thought could possibly kill the fire and finding everything good I decided the new CDI had to be bad. Ordered an OEM CDI and installed and all is well. The previous CDI I had ordered was a half price after market CDI which was stated to be specifically for the `87 foreman. Lesson learned.
Dylan Reid
Ask the Editor
Nov 25, 2021 02:29 PM
frostytj
Oct 6, 2018 11:06 AM
Bmbhman@hotmail.com
CAN-AM (BRP) Ask an Expert!
Oct 3, 2018 08:41 PM
frostytj
Sep 24, 2018 07:15 PM
