2004 rancher 2wd 350ES not running
Old Dec 30, 2018 | 09:22 AM
Mark Tkachik's Avatar
Default 2004 rancher 2wd 350ES not running
TRX350ES cranks over and sputters but wont run.
1. replaced battery (still nothing)
2. made sure it was getting fuel
3. rebuilt carb (still nothing)
4. checked compression (90psi)
5. even replaced carb (still nothing)
The only thing that happened at the near or the same time is the dash went completely dark. Any suggestions on how to test the ICM and or Ignition pulse generator?
Old Dec 31, 2018 | 03:20 AM
First thing to check is if there is a good spark. If you have a good spark, there is no need to check the pulse generator. 90psi isn't all that good, though having an auto de-compressor tends to make the figure a bit low. Check and reset the valve clearances, this could help the compression.
ken270
Apr 16, 2018 03:53 PM
judy bell
Mar 29, 2008 06:57 PM
kingdiamond
Mar 16, 2006 05:06 PM
jumpman23
May 29, 2004 01:32 PM
Rudnik
Apr 23, 2000 12:23 PM
