Linhai Manco Talon 2005 grinding problem.
Old Jan 13, 2019 | 11:42 AM
Nick8995's Avatar
Default Linhai Manco Talon 2005 grinding problem.
So first off we were just driving the atv around the other day and then it started to die at a low speed. Put it back into neutral and turned it off and back on after about 3 minutes. Tried to shift it into gear and it’s started making a grinding noise. I also noticed the throttle was sticking some so I was wondering about that. Any ideas on how to fix this issue? Thanks!
Old Jan 14, 2019 | 03:32 AM
If the bike has a centrifugal clutch, the revs need to drop low enough for the clutch to disengage before you can put it in gear without grinding. Clean the carb out, making sure the slider or butterfly is moving freely, check the cable is free, and try again.
Old Jan 15, 2019 | 08:06 PM
Nick8995's Avatar
Default Used often.
The quad is actually driven very often so I don’t think it would be the carb. I’m thinking it might have something to do with the clutches. Any idea on how to fix it?
Old Jan 16, 2019 | 02:47 AM
A bit of grit can get into a throttle slide anytime. Throttle butterfly spindles can stick on bikes used all day, everyday. An air leak can raise idle speed. If the idle is too fast, fix it before looking for clutch problems.
Old Jan 16, 2019 | 09:37 AM
Nick8995's Avatar
Default Idle speed
we already reduced the idle and it’s still making a grinding noise. Not sure how we would fix the clutch though.
Old Jan 17, 2019 | 03:21 AM
Right, just googled it, and it looks to be a similar set up to the Suzuki LT80 with a centrifugal clutch after the variator. So it could be the variator pulleys sticking, so driving the clutch at high speed all the time, or it could be the centrifugal clutch, either seized, or a shoe stuck out and grabbing the clutch drum, often due to a broken pull off spring on a shoe. Here is what the clutch, and back part of variator looks like
Amazon Amazon
Old Jan 17, 2019 | 09:24 AM
Zrock's Avatar
Super Quad Patrol
How low did you set the idle.. They are set lower than you actually think by ear i had to set it just a hair above stalling..
Old Jan 17, 2019 | 11:00 AM
Nick8995's Avatar
Default Idle
we did reduce it a lot and seemed like it was at about stalling speed. I guess we could try lower not sure if it’s an idiling issue though.
Old Jan 17, 2019 | 11:02 AM
Nick8995's Avatar
Default Clutch
Right, just googled it, and it looks to be a similar set up to the Suzuki LT80 with a centrifugal clutch after the variator. So it could be the variator pulleys sticking, so driving the clutch at high speed all the time, or it could be the centrifugal clutch, either seized, or a shoe stuck out and grabbing the clutch drum, often due to a broken pull off spring on a shoe. Here is what the clutch, and back part of variator looks like https://www.amazon.com/Clutch-Driven.../dp/B00SF2P276
so do you think the whole clutch needs a replacement? Also how hard of a job would that be? It’s still drive able so not sure if I would want to replace a whole part.
Old Jan 18, 2019 | 03:36 AM
"so do you think the whole clutch needs a replacement? Also how hard of a job would that be? It’s still drive able so not sure if I would want to replace a whole part."
Take a look at it, inspection is the only way to find the fault, but at $72 for the whole thing, I doubt if they bother selling individual parts. It could just be something sticking, and may work fine once freed off. Belt replacement is a regular thing, and removing the clutch is probably needed for that, so no big deal.
