Engine will crank but wont turn over
Old May 12, 2019 | 11:04 AM
ashtx's Avatar
Default Engine will crank but wont turn over
2011 Polaris Sportsman 800 EFI
So i was tiling some stuff the other day and i took a break and guess what the atv wont start. This is what i have done so far.
Checked battery, starter solenoid,Fuses, Wiring harnesses, Starter bendix. Fuel lines for fuel. Fixing to check fluid pressure as soon as i find a guage. However i dont believe thats an issue as squirting fuel into the spark plugs well doesnt seem to make it turn over.
Checked for spark and changed spark plugs as they appeared a little foul still no change.
No error codes on diagnostics.
I am not sure where to go from here.
Any and all suggestions welcomed.
Old May 18, 2019 | 08:51 PM
Washingtondave's Avatar
Ruff RIder
What do you mean "tiling some stuff" do you mean trying? And what exactly were you doing. Hard to diagnose any issues without the complete story.
You state it cranks so it is probably not the battery or Starter. Is the plug getting power? Check all the connections. And if you do not have proper voltage the machine wont start.
GLI
1) Engine problems..
14
Mar 29, 2012 12:08 AM
tja349
Feb 25, 2009 06:52 PM
dandya
Apr 10, 2008 02:25 PM
lilMike
Jul 9, 2004 10:24 PM
