Why wont my engine turn over??
Old Jul 9, 2004 | 06:27 PM
lilMike's Avatar
Default Why wont my engine turn over??
Ok i've been having the 102mm piston, but i just put in a stage 2 and kibblewhites along with 1mm oversize valves. Set my timing over and over and I cant turn the engine over with a ratchet and socket in normal(counter-clockwise) direction. But yet it turns over clockwise with no problem. Cant understand why it turns one way but not the other? Any idea's?? Thanks, Mike.
Old Jul 9, 2004 | 09:16 PM
XxDumontRaptorxX's Avatar
I know you are only suposed to turn it over in a certain direction, I dont have my manual handy so im not sure which direction it is suposed to be turned over at. I do remember mine being able to go both ways though. If the cam is lined up, and the timing chain isnt getting caught on anything (forgotten part) I am not too sure. Someone is bound to reply with something useful.
BTW i do remember myself dropping something down the gap where the timing chain goes from the head into the case, its easy to lose stuff down there.
Old Jul 9, 2004 | 09:28 PM
yzbluebeast631's Avatar
The motor is binding on something. Piston hitting a valve?? Cam chain sliders not installed properly???
Old Jul 9, 2004 | 10:24 PM
lilMike's Avatar
Problem solved... i was a few teeth off on the timing. Everything is a whole lot closer tolerances now. Dyno #'s soon!!
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
Shifts
Jul 3, 2015 07:59 AM
bikedad3
Jul 2, 2015 02:15 AM
