Need a clutch kit or other idea 13 500 w/ebs
Old May 12, 2019 | 09:41 PM
01sportsmna500's Avatar
Default Need a clutch kit or other idea 13 500 w/ebs
So i was doing some spring maintenance on my 13 500 ho/ebs and found my helix is gouged pretty good as well as the rollers. The primary clutch weight pins are worn as well as the holes in the weights. I figured no big deal i will order up some replacement parts and be good to go. I didn't realize the helix alone is $350??? So I start looking for a kit figuring i could likely save a couple hundred bucks and maybe upgrade a bit and get all the parts in one shot, but i cant find one with a helix for a 13 500 w/ebs. Has anyone seen one? Or know of an aftermarket helix that doesn't cost quite as much? With weights and springs id be at $700!
Old May 12, 2019 | 10:09 PM
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
The first place I would check is EPI. The second would be Dalton. Niche also makes some copies of Polaris clutches but I don't know what they do and don't have. Those are the first 3 that come to mind but there are several others. AAEN has a lot of Polaris stuff. Rick Ritter at RCR seems to know everything about Polaris but I think his specialty is getting more performance out of 400 2-stroke engines.
https://epiperformance.com/polaris-16/
Old May 13, 2019 | 08:32 AM
Thanks, i'll give them a shout. Heres a pic of the damage
Old May 13, 2019 | 01:27 PM
EPI found me a kit, same as an 08-09. Thanks for the tip
toolman4
Jan 6, 2020 09:37 AM
SCA
Feb 7, 2004 04:37 PM
markie
Dec 18, 2003 06:16 PM
pol5002
Aug 25, 2003 10:14 PM
