Prairie 360 4x4 issues
Old Sep 18, 2019 | 11:55 AM
industrymoto's Avatar
Default Prairie 360 4x4 issues
So the 4x4 quit working the other day, No light, but I can here a slight tick at the actuator when the switch is activated. Ofcourse thats with the engine off and Ignition switch on . I replaced the actuator and get the same results. So I got a Kbec Delete and installed it. Now the 4x4 light comes on with the switch but still will not engage, So I installed a new speed sensor and that did nothing, The slide in the diff is free and I can lock it in manually.Checked all fuses and they are good. Now Im lost. Any Ideas??
Old Dec 27, 2019 | 09:31 AM
K3604X4's Avatar
Sounds like a dead battery or loose cable/bad connection.
Old Dec 27, 2019 | 04:27 PM
Kymco 450i's Avatar
Electrically operated stuff does require full voltage and clean connections!! A poor electrical connection can cause all kinds of issues as can a battery with a bad cell. Have it load tested to see if it holds a charge. Even new batteries can be faulty sometimes.
Brandon Johnson
Apr 1, 2018 09:19 PM
hburg_atver
Nov 23, 2009 01:59 PM
hburg_atver
Oct 26, 2009 03:54 PM
SumnerPrairieDog
Apr 9, 2008 12:02 AM
cre
Jun 4, 2002 11:16 AM
