2008 Sportsman 500 HO EFI cranks, but won't start
Old Oct 18, 2019 | 03:31 PM
jdabling's Avatar
Default 2008 Sportsman 500 HO EFI cranks, but won't start
HI, all. My 500 won't start. I replaced the battery. All the lights and control panel work. The 4 fuses under the front are all good. When I turn the key on, I can hear a little noise that I believe is the fuel pump, and when I turn it off, I definitely hear clicking and noises that I believe are the fuel pump. The new battery was putting out ~12.5V, and the spark plug is putting out spark. I replaced the spark plug for good measure, but the old one didn't look fouled or anything. No codes in the system. Air filter didn't look too bad, but even with the air filter off completely, it wouldn't only crank, but not even turn over. So, I got some starter fluid and sprayed that into the air intake when I took the filter off. Now, when I try to start it, it makes more noise. It sounds like it is starting to turn over, but just won't get to a self-sustaining level.
Any ideas? I appreciate any comments or advise. I don't want to take it into the deal, because I know that will be expensive, but I don't have a lot of experience with these machines.
(Note: I did see this thread: https://atvconnection.com/forums/pol...-no-start.html, but I'm not sure it's the same issue. But, if people feel this is somehow also a wiring problem, I can look into that.)
Thanks,
Jeff
ashtx
May 18, 2019 08:51 PM
Aventb
Jun 15, 2018 12:30 AM
JPBLLV
Nov 28, 2013 09:34 PM
khentige
Dec 13, 2011 06:54 PM
jethrob
Sep 7, 2010 07:38 PM
