2000 sportsman 500 creeping in gear at idle
Old Dec 12, 2019 | 10:40 AM
bsanstra's Avatar
Default 2000 sportsman 500 creeping in gear at idle
I just purchased the atv 2 weeks ago.
I replaced clutch with new one and it still creeps at idle in gear. idle is around 1000 rpm. could it be the clutch shaft in the engine moving in and out? should i try shimming the secondary clutch?
2nd question. it has about 415 miles and 66 hours on it. is there a way that someone could alter the hours and miles on it maybe with a new speedometer?
Old Dec 28, 2019 | 08:21 PM
jrsavoie's Avatar
I'm no help other than suggesting you search for clutch and creep issues for Sportsman.
I am battling the same thing myself. On my machine the clutches were way out of line. I had to loosen the transmission and twist it what I could to get it in line.
I started out with a bad motor mount and had to fix that before I could go any further.
There are several things that can cause creep. Poor clutch alignment, bad motor mount and wore clutches being a few. I am wondering how much sitting your machine has done and if oxidation inside the clutch from not being run enough could also be an issue. Hopefully somebody that can give you good advice will chime in soon
lowflyer
Dec 25, 2013 05:45 PM
BigRawJ
May 11, 2010 03:34 AM
bkfarrier350
Jul 6, 2009 05:02 PM
blamkin86
Mar 1, 2009 08:27 PM
Marksvilleman10
Mar 16, 2008 02:22 AM
