reverse
Old Dec 15, 2019 | 07:00 PM
dogger1953's Avatar
Default reverse
Hi I have a 2005 ribicon 650 and forward gear works ok but when I put in reverse feels and sounds like it goes into gear but the reverse indicator light does not come on and it will only creep backwards with very little gas reverse doesn't work
Old Dec 16, 2019 | 09:19 AM
dogger1953's Avatar
do I have to hold the brake down why shifting into reverse for the reverse indicator light to come on
Old Dec 17, 2019 | 03:17 AM
It must be 10 years since I had a Rubicon to fix so I can't remember, most Hondas have a red button or lever on the LH handbrake lever, press then pull that brake on. However the old Hondamatics had a button on top/side of the gear lever that you had to press before engaging reverse, and I suspect the Rubicon will be this type.
Old Dec 17, 2019 | 07:38 AM
dogger1953's Avatar
sorry for any confusion but it is a Rincon not a rubicon my mistake, but it seems like it goes into reverse and trys to move but acts like it is slipping I was thinking that I need the reverse indicator light to come on on the display but it doesn't light up
Old Dec 17, 2019 | 11:46 AM
dogger1953's Avatar
ok took gear position switch out grounded it and if I turn it neutral and 1st gear will show on display but no reverse I am thinking the switch is bad and not lighting up the reverse light on display would this cause the 4 wheeler not to move in reverse forward works fine
Thanks
dogger
Old Dec 18, 2019 | 03:13 AM
Extremely doubtful. The lever works the switch, not the other way round as a rule. ES Hondas and the new Autos do have a "lock out" switch to stop it trying to change into reverse if the cable from the aforementioned handbrake lever isn't pulled far enough, but in your case I would suspect the mechanical mechanism from the gearstick has jammed and isn't allowing the lever to go into reverse. Could just be the cable needs adjustment.
Surely someone who has a Rincon on here, can help more than me.
Old Dec 18, 2019 | 07:59 AM
dogger1953's Avatar
Talking
the switch is down by the oil fill pipe and is activated inside the sub transmission has a spring pin on it that sticks out further on one side it has automatic and manual shift on handle bar.
gear shift is up under left handle bar and has neutral forward and reverse. it is in reverse just wont move no reverse indicator on on dash I think it all works through solenoids at the front of motor where all the valves are for auto. I am thinking it needs to see it is in revers from the switch to operate the valves up front. I think it all works through the automatic control valves. I have ordered a new switich I will change it and go from there I think it should work once it gets signal from switich at least I am hoping.
Thanks
Dogger
Old Dec 23, 2019 | 08:09 PM
dogger1953's Avatar
Thumbs up
changed switch and that solved the problem thanks for all the help problem solved
Thanks
dogger
PolarisUK
Feb 27, 2006 05:42 AM
KILLER250R
Jan 14, 2005 09:37 PM
ArticCatBill
Jul 13, 2004 10:41 AM
Ward660R
Oct 23, 2003 09:32 AM
