Coolster Neutral Light
Old Jan 19, 2020 | 10:58 AM
Brandon Wilson's Avatar
Default Coolster Neutral Light
When I apply the brake to start, the neutral lights goes off. Nothing happens when I try to start. If I recall, the neutral light was illuminated when applying the brake. Any suggestions?
Old Jan 20, 2020 | 03:24 AM
Doubtful if neutral light and brake work together. Make sure the battery isn't flat, as the power going to the start circuit will put the light out if the battery is low. Next check the main wires from battery for bad connections, both live and earth, again the power to the light drops if there is resistance in those main wires.
mckroney
Jan 11, 2007 06:56 PM
dsdrew
May 4, 2004 03:05 AM
jiffy
May 3, 2004 02:57 PM
vtwiner
Jun 23, 2003 02:01 AM
HELMET660
ATC 3-Wheelers
Feb 16, 2001 07:38 PM
