neutral light comes on sometimes, faintly
Trace it all the way back. . . first, check the connection on the back of the light. . .make sure it is tight and all the way on. Next check the light (un-plug the red light and plug the leads from the green light into the red light. . . is it bright now? If not, check the wiring. Make sure it hasen't been exposed and rubbing metal / the frame anywhere. Lastly, check the neutral sender under the counter-sprocket. You may need a new one but, I have never heard of them failing like this.
fordfaithful21
12-07-2015 05:52 PM
Steeldon
09-09-2015 09:38 AM
