2005 Honda 400at
Old Jan 22, 2020 | 04:00 PM
Tiger-64's Avatar
Default 2005 Honda 400at blows control motor fuse
Looking for help, 2005 honda 400at blows control motor 30 amp fuse ,soon as you turn the key, won`t go out of 1st gear,unplug control motor connection up front and fuse does not blow , control motor turns when connected direct to battery,flashes code 12 , any help would be appreciated ,Thanks
Old Jan 23, 2020 | 02:42 AM
I will have to check what code 12 is when I get to work, but it seems strange that it would blow the fuse when you turn the key, as I would have thought it should only power the control motor when you engage drive. What happens when the switch is in Auto?
Old Jan 23, 2020 | 09:30 AM
Tiger-64's Avatar
same in auto
Old Jan 23, 2020 | 12:23 PM
Code 12 is control motor wiring fault, which you will get if you disconnect the motor. Never tried it, but I would strip the motor and see if you can find why it blows fuses.
Old Jan 28, 2020 | 05:31 PM
Tiger-64's Avatar
thanks , i`ll try that
dharrisauto86
Jan 10, 2011 05:17 PM
Jim_bo
Oct 19, 2010 12:36 AM
dalee3
Sep 15, 2009 09:40 PM
alisonsandmindysdad
Jul 19, 2004 11:16 AM
