Polaris Sportsman 700 belt slapping cover?? Help
Old Jan 26, 2020 | 08:16 AM
cquillen10's Avatar
Default Polaris Sportsman 700 belt slapping cover?? Help
I have an ‘05 sportsman 700 efi thats having belt issues. It started when i was using it in low range, i was on it pretty hard til i came to a stop and it started creeping at idle, like the belt was trying to engage, kind of made a slight knocking noise too. It was also very hard to change gears. I cut the machine off, cranked it up again and the creeping/knocking went away and it rode fine the rest of the day. Then recently the belt started making a bad slapping noise, sounds like its slapping the clutch cover. Doesn’t do it at idle, only when throttle is applied, louder when it’s in gear and throttle is applied. I’m thinking it’s either a bad primary clutch or belt??? What do you guys think??
Old Jan 27, 2020 | 06:07 PM
Powerranger262's Avatar
Going to have to open up the cover, and see what is going on inside. I'm thinking your belt came apart. You don't want to ride it like that. It will cut a slit right through the case.
Old Feb 1, 2020 | 04:44 PM
cquillen10's Avatar
Yeah powerranger i haven’t rode it since, and it could be the belt because i’ve noticed it slipping under heavy load before.
Old Feb 3, 2020 | 08:04 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
chances are the belt is damaged. take cover off as mentioned and replace the belt and blow out all the belt dust and clean the clutches and hope your one way bushing that works the ebs in the primary clutch isn't going bad. that is usually what makes the bike creep as you described.
Joe04785
Apr 30, 2015 08:23 AM
jsa
Jan 26, 2008 08:48 PM
chevyman142000
Jan 4, 2008 10:36 PM
Elimin8r
Aug 30, 2007 11:12 AM
